gearbox mount
completley p****d off
:bangshead:
bought a 91 wsei 2.1 pinto end of last summer (best car i have ever driven)done a complete rebuild shes back on her wheels loom in which i got from allen at premier looms
2weeks its been various mounts arrive no joy
missus texd me at work today its here looked the same in picture (carn't measure for the life of me)wrong again
help don't want a website or phone number want somewhere i can go an buy 1 and match it show shop not bother'd
need it on road end of month
Are We talking Type 9 Gearbox in a Narrow body here   ???
Also when you say it doesn't fit, How do you mean    ???
Don't get Too p****d off     :oops:
the more info' We have the better the chance of us helping     :t-up:
Where are you based?
the mount ive just got is a Quintal hazel
qh em680
fits box but like all sierra granada cortina mounts 2 tall an wide without altering car
last resort
somebody spent alot of money buildin her
lsd engine is sweet full spax adj.
Type 9 in a narrow body? Got mine from westfield here, but they are cheaper from caterham here
amazing price difference; Westfield are twice the price..
qh em680 looks about right from the picture Ive found on 'tinterweb but there's no dimensions so the image could be misleading.
Did you change the gearbox in this rebuild or are you just replacing the mount?  You'll be lucky to find a motor factors that would have one on the shelf given the age of the car theyre from but, as mentioned, WF or caterham will have exactly what you need.
If you've changed gearboxes then there's every possibility that the mount location will have moved which will bring with it a (very minor) chassis mod.
Damian
Damian
Yep, if it was a 4spd and now a type 9 you will need different location which may partly explain your problem. Lins too far for me to pop over (South Coast :D) ) but defo check mounting location is correct then get the right mounts from WF explaining that it's for a Type 9 into a Narrow.
On the plus side at least the syntax police haven't shown up yet.  :devil:  :D  :p
A few of us who changed from MT75 to a Type 9 box  had the same problem
You need to lower the chassis plate where the gearbox rear mount fits by about 25 mm or so  :t-up:
havn't changed a thing on rebuild just replaced all the parts its a type9 box with trick inners an quick shift
took the car 2 bits replaced all the rose joints balljoints
disc's pads shoes cylinders cables loom
cars sat their ready to roll just needs engine an box fitting when i stripped the car i was in heaven.
couldn't find anything 2 improve wish i had half the stuff when i was doing brisca f2
ps wide body :bangshead:
So if its had a type 9 in previous there should be no probs , wessy factory can supply the correct mount  :t-up:
One of  these u'ns
  • 1 month later...
