alternator rose joint link adjuster
found these on fleebay  :) thought it maybe of use to others,
going to get one for the denso alternator ive just fitted so i can get rid of the big ugly one,can get it in any size to :) should look ok fitted
               clicky
and no ive got no part in the sale of them :D
             johny
Thanks johny.
Can anyone confirm this is a correct length for a VX install? A good price? and also tell me what rod end sizes i will need?
M8 holes
Mine is about 100mm from bolt to bolt when tight
But it would depend upon your pulley / belt sizes ???
You could allways shorten it?
Dave
A word of caution if you do use one of these-
If the alternator uses the standard arm for earthing of the alternator & the rod ends are ptfe lined, make sure you fit an additional earth srap from the alternator to the block, otherwise it won't charge the battery...... :oops:
How much is it with the rod ends and half nuts?
