Tell us about your latest upgrade
Thought it would be a good idea to share all our upgrades that we seem to under take relentlessly, no matter how big or small ...
Just this week I have fitted some wind deflectors, purchased off ebay for 50 squid plus posatge - and also shaved a bit of the front edge of my cycle wings as they had a big crack right at the front which has bugged me since I purchased the car (that dremel is great for drilling fibreglass) ....
Anyway, what are you fannying about up to in your garage?
This winter..
ST170 Engine
Raceline Sump
Arp Bolts
Idler Kit
Full Throttle shift (clutch switch to Emerald ECU)
100mm Ram Pipes, new deep Pipercross Filter
Mickmade carbon backplate
Bonnet cut for above
Boonet scoop to clear VVT Cam hump
Carbon Chassis protectors
Rally Design Widetrack kit (all new ball joints etc)
Poly bushes
Quick Rack
Carbon nose cone floor
Alloy Rack mounts
Bullet Cam and DVR recorder
And I am sure a few more bits and bobs before it gets taxed.. upgraditus at the mo..
PS. Dont tell the wife.. :-)
Loads of maintainence type stuff:
Chassis - powder coat touch up
Steering rack bellows
Lower steering column UJ replacement (more involved than you think - machining etc)
Dashboard electrics tidy up + replace old rocker switches with illuminated ones etc etc.
New carpets
Paint brake discs ( not friction areas!!)
Stone chip protectors
This has kept me out of trouble most of the winter, once this is done, the more significant mods will be made ;) Roll on March so I can re-tax  (this could be the only Tax I am happy to pay!)
Just finished putting the engine and gearbox back in  after fitting new E3 HD 20.Sporting gearbox from BGH. and then one or two other things, 2.4 steering rack, removable steering boss and racetech wheel, front uprights and wishbones re powder coated, new set of R888 £71 inc vat and postage(camskill).
I only took it around the work shop to clean it!!! ???
Power hike for the engine. Eight injectors bigger throbbing botties etc etc :D
Just fitted Gaz Golds.
Alloy Radiator & Samco Hoses.
4 Wheels Powdercoating & New Tyres.
Find 4 lightweight wheels to fit 888's for track days.
Recover Rear Roof Section.
Carbon Exhaust Cover.
External oil feed to head.
Lower Drivers Floor  (Maybe)
Midilte front calipers
Simpson exhaust
Paint rear calipers
Poss wide track
And few other little bits :xmas:
b****y hell I thoug I had been busy - Clegg's doing all the cheap stuff  :p  :p
Carbon Tub flaired side panels
Carbon Dash
Carbon cycle wings
Carbon Wing mirror covers
Carbon Boot lid
Carbon chassis protectors
Carbon inner cockpit panels
Carbon floor panels
Carbon panel behind seats
Carbon number plate
Carbon (only effect) front indicators
Team dyno wheels with parada tyres (black)
M and P lights
Savage switches for the dash
Oh and some other carbon bits....... :D
and a new camcorder just need to sort the mounting bracket.
Not sure about it being an upgrade, but I've removed the aeroscreen and putting back the windscreen!!
Also, got a set of 2 ltr cams to fit as well.
John
tbh I like the little upgrades, the things that make a car non standard - it's all good
Photo's guys - come on lets see what your up too
Changed the diff, 3.89 to 4.125.
Wider offset rear wheels.
New 048R's.
Bit more engine map tweaking.
Oh, and I might wash it....but then again I may leave it another year....
Water/Methanol Injection
Bigger Ally Rad
Stiffer Front Springs
Retrimmed dashboard
QuickShift Kit
Tax and drive :cool:
After fitting: :)
Carbon Dash
Carbon boot lid cover
New Speedo
New Rev counter
After I've moved house :bangshead:
