Big thank you to Scruffy
:D  :xmas:  :D  :xmas:  :D  :love:  :D  :love:  :D  :)  :D Well thanks to the very keen spannering by our very own Scruffy (Hugh in the real world), i've got me car back together.
The irony is that the one bit that caused all this grief (type 9 remote) had to be removed and is sat nicely on the bench. I did smile at that.
Hugh i can not say thank you enough, i even have your radio as well.
I recon on a bit of hammering to fix the oil filter issues, and aparently we have found one at 55mm deep.....so we shall see, a job for the weekend i think.
Again Thank you Hugh.
[que applause]
:p  :xmas:  :D  :p  :D  :D  :D  :D  :D  :D  :xmas:  :love:  :cool:
Thats your radio :p  Had we not had the oil filter issue (and lost 3 hours to it), I reckon I'd have got it running.
I'm not sure what is causing the issues with the oil filter, does chaz know if the filter used to sit under the column or beside it?  The engine has to be pretty much in the same place as it was as the exhaust is spot on, so it has to be a difference in filter or pump housing.  For some strange reason that car is considerably more fiddly to wok on than the dax and the dax has 2 water radiators, and intercooler, remote oil cooler, cone air filter, masses of piping and a turbo stuffed under the bonnet.
I was going to drop you an email with whats left, but might as well post it here.
Exhaust collector bolts - tighten
Prop/ diff bolts tighten
Tighten all 6 gearbox mount bolts.
Bolt missing from passenger engine mount
Fit carbs and air filter.
Check electrical connections
Fit hoses to rad
Breather pipes need connecting
Fibre washer for filler bolt  on gearbox#
Coolant, engine oil., gearbox oil
Connect battery earth
Well done Hugh, mine next...................
When you bolt the remote back on you will not need to
space underneath it with washers as I've set it up without.
You'll need a spring washer under the three seccuring bolt heads.
I've pre-adjusted remote it's self so you wont need to fiddle with it, just bolt it on and it should work ok.
Did you manage to cross-ref the Wix filter number I gave you?
Chaz.
This is not a good thing to say to Mark. He tends to use the spanner with the 12 foot handle  :p  ;)
...but well done. Where is the back of the queue ;)
You can go to the front of the queue Liam if your sandblaster works and you can get a 13" wheel in it :D
Good work Scruff!
I had Mark's old coil pack bracket, complete with his pressure regulator mounting holes, with me on Sunday. Didn't think to give it to you...
:blush:
Oi.
No queue jumping.
Scruffy is supercharging my bus next*
* he is if he wants to keep the Dax in my garage for any length of time. :)
Seems like the best option for all is for Scruffy to set up shop in Sams garage... then the queue can form up nice and neatly on the drive :)
I did some extensive filter reserch last night and about 50-55mm seams possible with a Fram 2874. or the WIX Wl7064.
Others include:
Fram Ph2830
Fram Ph 2825A
loclhead LH1051
Coopers Z87
Halfords 266
Crossland 659
Elf 298
Mahl ce11
And a unipart one that i forget the name of.
I also seam to now own a new radio CD player, as well.
I had a good look into the inlet ports last night, the porting/smoothing job looks fantastic.
I'll have a crack at it this weekend and see what we can do with the various bits to finish it.
On the bolt tightening front, any ideas of the EERRR that i need to set the tourque wrench too, is is "tight" and "chuffing tight" OK. I'm thinking the bellhousing bolts and prop ones here.
I saw the missing mount bolt, I was going to give it a quick spanner over so that i new i hadn't missed any.
Fider washer, do you think i could do this with some cardboard? or a rubber O ring?
Again Thanks mate, really apreachiate it.
Sparky, best get the dixis over here as we will ahve it done soon.
Chaz, i hear you on the extension, just 3 bolts, i'll be fine. Even got some new anti rattle bits somewhere......and i painted it.
Top man Hugh...this is why the WSCC is such a fab club  :t-up:
If Mark offers you his grass cutting services in return....well you know what to say  :oops:
The bellhousing to engine bolts should all be FT.  Assuming I didn't miss one.  The fibre washer would be best as some sort of thick robust item, it just needs to seal on top of the nut to the underside of the bolt head as its not a machined surface.
I was thinking of setting up a business on a part time basis and was wondering about premises.  What are your rates like sam?
Halfords 266
Careful with that one. I read that on here as well, and it is for a post 84 Renault of some description. Renault change from 3/4" UNF to M20 around 84. So whilst the M20 might appear to fit fine when it is tighten up, it will be like a wizards's sleeve up until then and is at risk off falling off.
QUOTE
Bluddy dear considering £270 worth of floor paint only just did one coat :(
