VHT wrinkle paint finish
is this stuff any good or should i steer clear,its for timing cover and small brackets etc,ment to have a nice wrinkle finish to it :)
    johny
    johny
It's very good if you do it right.
Spectra was the manufacturer of the stuff I used.
It does need care and can only be applied to bare metal from what I recall. Also you can only give one heavy coat, it cannot be over coated so if you dangler it up it means stripping back down and doing again. Its very hard when fully dry, which doesn't take long, but as a result can chip. I actually think it's a superb finish. Can't recall what the performance should be like on hot parts as I only did a set of speaker stands ;)
My Pinto cam cover has it. Now done 17000. Good as new and it gets very hot under the bonnet. .
  • 11 years later...
Thanks a lot for your feedback !
 I'll see if the local powdercoating shop can do such a job, if not I'll default to VHT wrinkle plus, on a sunny day...
I got good results on my rocker, I used made an oven out of a wooden box and an electric bar heater :)
6 hours ago, RussH said:
made a massive fire hazard out of a wooden box and an electric bar heater
Fixed that for you...
Thank god I’m still alive!
Was over 11 years ago but if it helps.... 🤣
  • Haha 1
Well, it was intended to go there ->
But I think the "post editor saved to session" + too many opened tabs had me in full thread excavation mode...
(and not for the first time)
Getting close to the “holy thread resurrection Blatman” award 2020 there 😁
  • Haha 2
  • 2 months later...
Just found this myself as am looking to use this stuff on my new engine cam cover, a guy on IG recommended - looks awesome when done right 😍
Yep, available in a few other colours, too.
(had to google for what IG was.)
  • Haha 1
  • 1 month later...
Done mine now
Write up in my build thread if anyone’s interested.
Send it in to the mag...
