I did go for the Caterham version which bolt in rather than clip on. Little real difference except that I don't think Sabelt will supply the bolts to swap your current eye bolts. Persomal preference - makes them harder to knick! That's the only difference AFAIK.
Pull up or pull down - that's another debate! Either have their compromise - I have pull down on the laps for which you can get to the tails easily, but they're harder to pull. Swings & roundabouts to be honest. I have a cunning plan to add a device to overcome this, but that's another story!
If you in the future intend to have a go at sprinting you will need 3" 4 point. I personally use Sabelt clip on but have fitted split pins to the metal clasps, just for added peace of mind.
And because Scrote can give you a flea in the ear if they're not there :D
Just reading this thread has 'prompted' me to think about changing mine.
I need the Caterham style for the Xtreme, just 1 question are the Sabelt lap straps pull up or down ?
I think you can specify
I was first interested in the Sabelt harnesses (ratio price/quality). After some reading on the forum, I took contact with Prima Motorsport, very good contact !
I think I am going to order there. As they are made on order, They give the choice for the fixings and for the pull up or down lap belt. What is the best : up or down ?
I guess the up is easier for tightening once you are sat in the seat. I currently have 2" wide Sabelt's and they pull down and are a pain to tighten when seated.
I have Sabelt 3x3 (sholder/laps) with the alloy sholder adjusters and am adding crotch straps too.
Pull down to tighten on on sholder and pull forward on the laps.
Comfortable and easy to use.
A vast improvement on the 2x2 Willians I had initially.
Chaz.
Just been doing a bit of price online checking and it seems to be that Europaspares seem to be the cheapest at £115 for a 3x3 Caterham type, compared with Demon Tweeks at £140
and around 77 pounds (ex VAT) for a Titon harness from Primamotorsport... not bad.
