Pinto Lumenition
Evening all,
I am running a pinto fitted with Lumenition Optronic and i am in need of a replacement ignition coil but there are no markings or numbers on the coil, so iwas wondering if anyone has a part no of a coil they have fitted or could recommend what type needs to be fitted.
I have a  :) bog standard coil on mine gives me no probs and revs to silly speeds :D  :D
Lumenition do coils and ballast resistors that will work with their optronic system. They are not outrageously expensive.
I had some problems with my Lumenition based ignition system earlier in the year. Turned out the root cause was the wiring and hidden ignition cutout switch a previous owner had added that couldn't take the current, resulting in voltage drop. When the engine was starting the voltage dropped so low the Luminition box stopped working. While I was working all this out I found out a lot about Lumenition systems.
You can download an optronic manual from the manufacturers web site http://www.newtronic.co.uk/new/main.php/lumfitv PMA50 installation instructions. It says that the coil, or coil + ballast resistor combination should be greater than 3 ohms and the coil primary side resistance should be greater than an ohm. The coil that was fitted to mine was a low voltage coil, of just over an ohm, but there was no ballast resistor. I replaced it with a Luminition coil and ballast resistor, plus a relay to bypass the ballast resistor when the starter motor is energised. This gives a couple of extra volts when the battery is being dragged down by the starter motor. A low voltage coil apparently won't last long if run continuously without a ballast resistor.
(modified by)
Jen
Ah, that didn't work too well. It's a Lucas Gold Sports coil. No problems :t-up:
