tex Posted October 15, 2008 Posted October 15, 2008 to fit mega busa or wide body - (will measure if in doubt) good condition easy to bolt on £230 new - £180 collect only
vt-marty Posted October 16, 2008 Posted October 16, 2008 alright Tex i take take it your a teessider from that signiture? im down by redcar... couple of Q's on these roll bars... 1. is it higher than the westfield chromed rollbar i have now? i think it is from what ive read. 2. will it prevent use of the roof? again i think it may do if its higher. 3.i guess id have to chop my boot box and rear bot cover?
MCB Posted October 16, 2008 Posted October 16, 2008 alright Tex i take take it your a teessider from that signiture? im down by redcar... couple of Q's on these roll bars... 1. is it higher than the westfield chromed rollbar i have now? i think it is from what ive read. 2. will it prevent use of the roof? again i think it may do if its higher. 3.i guess id have to chop my boot box and rear bot cover? Yes to all 3 questions
vt-marty Posted October 16, 2008 Posted October 16, 2008 good answer think i'll give it a miss then... shame as i want one but want to retain the possible use of the hood... if i went RAC i may aswell ditch the whole roof system, windscren and wiper/heater stuff... weight loss and more racey but maybe not for me..
stantman Posted October 16, 2008 Posted October 16, 2008 If you will consider postage I would be interested in first dibs. Cheers
tex Posted October 16, 2008 Author Posted October 16, 2008 If you will consider postage I would be interested in first dibs. Cheers yes postage is an option if you sort that out its yours my friend... pm sent
tex Posted October 16, 2008 Author Posted October 16, 2008 Your an expert on them now Tex eh ;-) lol - yea right - replying on others knowledge to answer some questions i cant - dax yea - westies - new to me..!
Mark B Posted October 16, 2008 Posted October 16, 2008 alright Tex i take take it your a teessider from that signiture? im down by redcar... couple of Q's on these roll bars... 1. is it higher than the westfield chromed rollbar i have now? i think it is from what ive read. 2. will it prevent use of the roof? again i think it may do if its higher. 3.i guess id have to chop my boot box and rear bot cover? 1) Yes 3" higher 2) No you can still use the hood, but the frame needs two bars removing from it. 3) Yes the boot tonneau needs modding & so does the bootbox, see westfield world a couple of years ago when I did an in depth article on how to do it. HTH Mark.
vt-marty Posted October 16, 2008 Posted October 16, 2008 alright Tex i take take it your a teessider from that signiture? im down by redcar... couple of Q's on these roll bars... 1. is it higher than the westfield chromed rollbar i have now? i think it is from what ive read. 2. will it prevent use of the roof? again i think it may do if its higher. 3.i guess id have to chop my boot box and rear bot cover? 1) Yes 3" higher 2) No you can still use the hood, but the frame needs two bars removing from it. 3) Yes the boot tonneau needs modding & so does the bootbox, see westfield world a couple of years ago when I did an in depth article on how to do it. HTH Mark. cheers Mark note that my car is a 92 and the hood frame is simply 2x bent tubes that lay aroud boot box when not in use. its not a fancy hood frame like the modern westy hoods. good info though cheers marty
Mark B Posted October 16, 2008 Posted October 16, 2008 Ah Right, I'd still try it though, if you fit the hood on without the frame hoops, if you have a 3" gap between your existing rollbar & hood then an rac should be ok. Otherwise some folks have had an extra piece of vinyl sewn in to extend the hood to fit onto the tub..... Like yourself I wouldn't be without a hood, not unless I move to the south of france anyway! Cheers, Mark.
kermit Posted October 16, 2008 Posted October 16, 2008 If the sale falls through, I will take it if it fits a 2002 SEIW I understand the mod required (I think)
vt-marty Posted October 17, 2008 Posted October 17, 2008 WELL LADS, THANKS FOR the info. seems like ive done some of the donkey work here in letting people know it fits/can be made to fit... and i havent bought it. :-) not to worry. i suppose i should check this 3" dimension and see if it would fit then i can get one if required.
Webby Posted October 18, 2008 Posted October 18, 2008 WELL LADS, THANKS FOR the info. seems like ive done some of the donkey work here in letting people know it fits/can be made to fit... and i havent bought it. :-) not to worry. i suppose i should check this 3" dimension and see if it would fit then i can get one if required. Umm always the way me thinks I would be interested if this fall through
