3.14 Ratio 7.5" Open Diff
Anyone interested in a 7.5" 3.14:1 ratio open diff with low miles??
Cheers Dave
as rare as hens teeth :D
is this a sierra unit? how much work would it be to wedge this into my busa with standard freelander diff?
thanks
dave.
Yes this is Sierra so a little bit of work but not much im sure. Regards Dave
How much for the diff?
Yes this is Sierra
Not if it's a 7 1/2" it isn't
thanks
dave.
wouldnt be worth it, you would need to swap driveshafts etc and not a lot to gain swapping from a 3.2 freelander you would get a bigger gain fitting larger rear tyres  ;)
Its from a Sierra 2.8 automatic estate.
Find one of those on ebay!!
These units are a hell of a lot stronger that the freelanders also the LSD's are a bit easier to come by. Bailey Morris will do the drive shafts for about £300 and Im sure AB performance would fit the sierra diff with little problems. (Andy is sorting mine at the moment).
It'll be a 7" then
I wish it was a 7" as it would be worth MUCH more money.
You have PM
