X-Flow Distributor Blanking Plate
As above really - following installation of electronic ignition I don't need a distributor so I'd like to remove it. Is a blanking plate / plug / whatever available, or do I need to make one?
Rich
I've heard of people using a core plug.
Personally I made one, or rather got a mate to make one for me    :cool:
I'd ring Vulcan Engineering or Burtons for advice. They'll know what to do and what's available...
Aaah that old chesnut....I know Burtons don't do them, cus I've rung em.  I'm ( still ) sure someone could make a batch and sell them on easily -I'd buy one.
There have been past threads on this, never sorted to my knowledge ( I've left the dizzy in)
I made one.
A flat piece of metal, slightly larger than the hole (like a solid washer) and secured with the existing bolt.  :t-up:
Thanks for the tip Jon - a good plan in the absence of anything easily available.
Rich
I made one.
does it seal ok being secured just on the one side ?  or does a good gob of goo help??
sounds like a plan -that old dizzy must absorb 1bhp
Must be possible to use an old dizzy, hacked about to leave the bottom of the body that fits into the block. remove the shaft, cut off the top etc, weld a plate on to seal it. Then it'll clamp in as intended and should seal ok. Don't want to do this to mine tho as it's an Aldon job.
I've had a core plug in mine for over 5 years with no problems
Used a core plug for the same thing on my 4age. Plenty of guys on ebay selling them, just gave them the diameter, cost me £3!
I made one.
I used the dizzy securing ring thingy as a template and used silicone as a seal. :cool:
