tankerman24 Posted September 6, 2008 Posted September 6, 2008 Im Interested in some Wheels Ive seen for sale they are 15"x7J ET 38 with 195/50 15 tyres, Ive ordered some new tyres for the Seight 205/50/15s the only numbers i can find on my wheels are 7J 15 e13 . they are the original Westfield wheels . Right the questions ;- Will the wheels fit my SEight ok and look right with that Et and will my tyres fit ok on these wheels as they are a different size. thanks Quote
CedricTheBrave Posted September 6, 2008 Posted September 6, 2008 tyres should fit wheels will be 25mm further in so you will need to make sure they don't foul the damper springs Quote
Blatman Posted September 6, 2008 Posted September 6, 2008 You can always add longer studs and spacers... Quote
chappers Posted September 8, 2008 Posted September 8, 2008 205 wide tyres will fit fine on a 7" rim. As blatters said, longer wheel studs and a 25mm (hubcentric) spacer will make the offset et+13, the same as your old wheels. Quote
