1993 sei buid manual
Please can anyone help me get hold of a copy of a build manual as im having a few problems getting the car back together. Im in the oxford area and im willing to pay for it. Cheers Dave
I have one from either 1989-1990 not quite sure, what are you after might be able to scan pages and e-mail to you?
Rear end and steering mainly really but the whole manual woud be great. Where abouts are you?? as I could come and pick up the copy. I really need the diff mounting in the chassis asap as the car is going off to AB performance to have the engine fitted middle of this week. If that is possible. Cheers Dave
Thank you so much that is fantastic and has answered almost all of my questions. I was having trouble lining the diff into postion not realising it needs the drive sfts in place before it is torqued down and also the orientation of the washers. My only problem now is the steering rack as mine is not from an ellegro. If I can help you in any way please let me know.
Regards Dave
QUOTE
Good! The steering rack should never be from an Allegro! Westfield steering racks are Mk1 or Mk2 Escort. Mk2 racks have metric fittings, so go for one of them.
The lower column is an Allegro. The upper column in a narrow is almost certainly Mk2 Escort.
See i skirt over the allegro bit and tell them that I have a bit of Aston Martin in mine.......the alpha ECU
Shames it's a not a good bit of Aston Martin. But never mind... :p
If anyone else wants a copy of the SEi early build manual I can e-mail it over in 2 pdf files as it is quite large.
Glad it helped get some way to resolving your problem Dave. :D
Sorry I mean upper column not rack :blush: . Thanks again Roman for the PDF's
