As above really - trying to do some repairs and my gel coat won't go off. I have gel coat hardener for epoxy gel coat, but I wonder if Westfield use polyester based material?
I'll try to call Westfield later, but wondered if anyone happened to know?
Rich
Hi,
It's polyester based gelcoat. Don't forget if you put your gelcoat on to seal it with tape so air cannot get in contact with the gelcoat when it hardens. if not your gelcoad will remain sticky.
Dirk
Thanks Dirk
Typical! I now have a sticky mess on the car to clean off then! Fortunately a small area.
Thanks for the tip with taping over the top - I wasn't aware of that.
Rich
Epoxy and Polyester hardners are not compatible .
You must use the correct hardner (catalyst) for whichever system you use .
You can also get  "flowcoat "  same thing as gelcoat but it contains a small amount (2%) of a special wax , which cures to a hard surface , eliminating the need for using cellotape to cover the repair .
Westfield coloured Gel coat
MEKP Hardener
Wax solution
Mix some hardener & Wax (2% of each by volume)
with the Gel coat
Bought from HERE
Saves b*******ing about trying to exclude the air using sellotape etc    :oops:
Hi Persky
Excellent - thank you.
I can't see anything on the site relating to MEKP -search results give me this. Could you tell me which one you chose please?
Rich
