For Sale. Westfield 5 Litre RV8
FOR SALE. 2007 Westfield 5 Litre  Rover V8
Due to another project, it’s time to sell one of the best Westfield V8’s in the UK.
Built by Barry Ashcroft and Steve Maund February – June 2007, Taxed till Dec 2008.
The car has done 3300. 320bhp and 350lbs torque, this is one of the fastest  road kit cars around.  I have receipts for nearly £30,000.00, the engine and gearbox alone cost £11.5k the specification is endless but please see below for the main points:
Exterior;
Black FW Bodywork, V8 Bonnet, (with added ventilation holes) and V8 Nosecone.
Carbon Mods, carbon rear arch protectors and CSR style carbon cycle wings and door sills
Led rear lights
RAC Roll Bar
Bespoke Luggage Rack
Westfield Doors
Bespoke Half Doors
Perspex Wind Deflectors
Westfield Fitted in-door car cover
Peter Walker Rain Cover
Gun Metal Gray Viper Stripes
Range Rover HST Side Air Vents
Suspension and Wheels;
Nitron’s with Team Dynamics Pro Race 1.2’s, Toyo 888’s 205/50/15 front and 225/50/15’s rear.
Interior;
Carbon Dash
Digi Dash Lite Dash, shows the following information;
Programmable Speed Display
Programmable RPM Display
Diesel Engine Compatible
Programmable Shift Lights
Engaged Gear (Calculation Based)
Coolant Temperature
Oil Temperature
Oil Pressure
Fuel Level
Engine Hour Counter
Real time clock on board (Date & Time)
Acceleration / Deceleration Timers
Road Legal non-resettable Odometer
Trip Distance Timer, Counter and Average Speed Calculator
5 Key Warning Lights
1 Configurable Warning Light
6 Programmable Warning Alarms
MPH / Km/h selectable speed
Display units in °C/°F/PSI/BAR
Latitude & Longitude
Altitude
Heading
GPS speed
UTC Date & Time
GPS Lap timing via GPS position
Traffic Camera Type
Camera Speed Limit
Programmable Alert in Metres to camera
Pre-loaded with over 10,000 UK camera locations
User can update camera database by subscribing to PocketGPSWorld
Switches for;
Lights
Fan
Fog Light
Wipers
Hazards
Horn
Removable Momo flat bottomed 270mm steering wheel (prewired for switches on wheel)
JK Composites Carbon headrest seats with padding
Leather handbrake and gear gaitor.
Lowered Westfield Floor
Engine built by V8 Developments
Top Hat liner cylinder block at 96mm nominal bore – cross bolted with 4 bolt mains
lightened and balanced Crankshaft – 86.36mm special grind
I-Beam Steel Rods – lightened and balanced
HyperEutectic pistons – lightened and balanced with valve relief
Stage IV Ultimate Fast Road Cylinder Heads – with double valve springs and late type stem seals
Polished and ported inlet manifold – 45mm and port matched.
45mm aluminium trumpet base – shortened radiused trumpets and ported housing
Balanced set of injectors
ACT Carbon Plenum Chamber with 71mm Throttle Body
V8Developments Stealth Camshaft – excellent fast road cam specially ground by Kent Cams
Hi Rev lifters
Vernier timing chain set – infinitely adjustable with a double roller timing chain
Complete valve train and rocker assemblies
Shortened Baffled sump designed for Westfield use.
Lightened and balanced flywheel
High Performance Motorsport clutch
R380 Gearbox
Bell Housing
Gearbox Remote
Lightened and balanced front pulley and damper
Oil cooler kit – 13 row with hoses and connectors
Late type ‘serpentine’ front cover and oil pump
Complete engine loom and ECU
Tornado ECU Chip Upgrade
Stainless Steel Exhaust Headers and manifolds
Gear Reduction Starter Motor
High Output Alternator
Mallory Electronic Ignition and distributor
Morosso Plug Leads
NGK Spark Plugs
High Performance Aluminium Radiator – designed for Westfield
Kenlowe 16 inch Fan
Shroud for radiator
This is a great car which is one of the quickest on the road today.
Priced to sell at £19,995.00 NO OFFERS.
Private Registration Number W7 FLD INCLUDED in sale
Call Steve, 07802 226414
What a belter !!!!! Someone is in for a treat.
This car want's for nothing apart from someone who knows how to drive it! :devil:  (sorry Steve) :D
A hell of a lot of car, speced up to the 9's..... :t-up:  :cool:
:(  :(  :( that is one dogs nads car  ;)  ;)  ;)
Have you wiped the passenger seat clean.?
Fabulous Motor Steve.
How about a part Ex. :D
Engine shots would be nice Mr Steve.........
Yes Steve show us the money shot!!!!!
For any of you who havent seen the car it is mint and finshed to a very high standard
Having been a passenger in it this summer in Le Mans it doesn't half shift too
Hope  you find a buyer soon Steve
Price reduced to sell @ £19,995.00 as I have seen my next car!
Steve
Be in doubt this car is one of the best Westfield SEiGHTS on the road, lots of spec for the money if you looking to buy a top of the range V8 with all the right bits  then look no further this car doesn't require any further money spending on it. Steve's a tart when it coimes to his cars and they are very much loved and pampered
Buzz
looks like the batmobile with that black cover on it !
Goes like it too.......... :t-up:
  • 2 weeks later...
BTTT don't worry Muttley I'll keep your add live!!
Buzz
Superb car and if  had a spare £20k then I would come and buy it off you! Sadly I am about £19999 short! :-(
Am sure this will sell soon as the spec is great!
