Where can I get one of these?
Anybody know where I can get another one of these highlighted in the photo.  83mm spacing bolt on K&N air filter.  I managed to knacker one, don't ask  :bangshead:  :durr:
QUOTE
How  ???  ???  ???  :devil:  :devil:  :D  :D
*IF* you can't find the proper one
You could always make one up by using a piece of studding (M6 or whatever) and then using a piece of Tube to act as the spacer
Unbelievable! I did exactly the same thing today and need the same part. I temp fixed it with a long M5 bolt, but don't do it up too tight! I was expecting to have to replace the filter so will be interested to see where this goes!
Eddited to add: have a spare extra bolt if you need one!
Hi Rich, I feel slightly less of a muppet now.  :D
Do you need a 83mm one?
Ditto Perksy - stud and a piece of tube.  Probably be able to source it in B&Q.
I might have one at home, will check tonight, yours if you PM me your address.
ditto the studding but instead of a piece of tube I've just used a couple extra nuts locked together to act as a stop when I've done it in the past.
Just for info for anybody who does the same thing, I have been onto K&N and they supply a pillar kit (containing 2x pillars) part number to order is 85-5014 and can be obtained through K&N retailers.  (this is for 83mm pillars)
can you grind the end off then drill and tap ?
Hi Bernie, possibly however I have ordered some replacements now.
First job in my new vice as well and managed to break something! :durr:
Cack handed Yorkite  :D  :p  :D
Unless you emigrated there from lancashire in which case you have a faulty vice  :t-up:
