I just use the side mirrors as I have binned the central one.  It was always in the way and kept coming unstuck.  Not sure of the legal position though.
You need two mirrors unless you have a Q plater in which a single central one will do. A central one is not compulsory for any vehicle AFAIK... for the MOT at least. SVA may be different...
Sounds OK then - thanks.  Never could see much out of the central one anyway. :)
I'm going to order one today, but I am still unsure about fitting.  Is a Racetech one an easy enough job?  Bare in mind, I can't screw a light-bulb in :p
QUOTE
That's OK.  A light bulb won't fit on the scuttle as there is no socket.   :)
