chippy Posted May 11, 2008 Posted May 11, 2008 Hi guys, im starting to get parts together to get my redtop ready to install! I need: Bellhousing for type 9 Flywheel Clutch Sump and pick up pipe cheers:D
Greenstreak-Andy D Posted May 15, 2008 Posted May 15, 2008 I have a vx std 'flat' flywheel and clutch assembly...Helix plate (suit type 9 input shaft) and std vx pressure plate...all originally sourced from QED....clutch done approx 5000 road miles..... In addition to what i have you will need a spigot bearing, release bearing and arm If your interested give me a call on 07729 847945 Thanks Andy
chippy Posted May 25, 2008 Author Posted May 25, 2008 Got a type 9 box now. Still need: Sump and pickup pipe Clutch Flywheel Inlet Manifold Bellhousing Cheers
VX2L16V Posted May 25, 2008 Posted May 25, 2008 http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?act=ST;f=8;t=63057 Carbs or TBs?
perksy Posted May 25, 2008 Posted May 25, 2008 Worth having a look and posting a Wanted Ad on Migweb Some of the VX Lads on there have got all sorts (Got my spare engine from there )
chippy Posted May 25, 2008 Author Posted May 25, 2008 TBs... Yes iv been meaning to register with that site! Mite have a quick butchers now cheers guys
chippy Posted May 25, 2008 Author Posted May 25, 2008 Cheers for the offer mate but im after the westfield sump or other makes like SBD and yukspeed.
chippy Posted May 26, 2008 Author Posted May 26, 2008 Will it allow me to fit carbs and TBs, because im planning on fitting TBs but obv the main issues is the budget an i mite decide to run it on carbs untill i can afford Tbs! regards chippy
