Bumble Posted May 9, 2008 Posted May 9, 2008 I am a new Westfield owner and a total novice mechanic. The sports silencer fitted to the car has developed a blow, at the studded end near to the short exhaust outlet. Can this be fixed by removing the end section and applying some gunk sealant or silican around the joint and replacing the end section? Or is it a matter of having to replace the whole silencer at a considerable cost? thanks for any replies. Quote
conibear Posted May 9, 2008 Posted May 9, 2008 Sounds like your implying it is a repackable type silencer, which if correct you can repair as you describe Quote
