RichP Posted April 27, 2008 Posted April 27, 2008 Hi all I've noticed that my diff breather is spraying oil out all over the place. I've got a ~6" breather pipe runing basically vertically which I thought would be enough to prevent this. What's the normal solution to this? Should I have a catch tank, or a different breather solution? I wouldn't have thought a catch tank should be necessary as I'd then have to be checking the diff oil level all the time. Thanks for any ideas / pics etc Rich Quote
Mark Stanton Posted April 27, 2008 Posted April 27, 2008 Not a long enough pipe - make abour 2' 6" and keep it as high from diff as poss then tie wrap it to chassis above diff - make it 3' or grab a diff breather - looks like a "bobbin" Quote
RichP Posted April 27, 2008 Author Posted April 27, 2008 3' should do it - I can tie wrap it up the side of the roll bar What's a diff breather then? Some kind of filter? I'll do a search! Cheer Rich Quote
CedricTheBrave Posted April 27, 2008 Posted April 27, 2008 is the plastic insert in the correct position? there is a little cut out that lines up with a mark on the diff. if this is not fitted correctly it will spray more than it should. I also ran a good 12" of tube up the chassis rail. Quote
RichP Posted April 27, 2008 Author Posted April 27, 2008 Plastic insert looks ok - it's set with the open side of the bit in the diff facing backwards. It's already bodged as the outer part of the plastic insert snapped off, so now has a piece of brake pipe pushed into it to join the breather pipe onto. I'll try a longer pipe...... Quote
Pingu Posted April 28, 2008 Posted April 28, 2008 If brake pipe is inserted have you reduced the effective pipe diameter? Is it breathing properly? Maybe get a new insert and 12" or more (way hey!). If you have a really long one coil it like Blatman says.. P Quote
RichP Posted April 29, 2008 Author Posted April 29, 2008 I guess there's a chance it's not breathing properly as the brake pipe is indeed a little smaller than the original tube, plus I didn't have this problem before....... New diff breather inserts seem as rare as the proverbial rocking horse stuff - ideas? No time to go scrap yard trawling in the near future, certainly not before Stoneleigh..... Cheers R Quote
CedricTheBrave Posted April 29, 2008 Posted April 29, 2008 its available from Ford as a new part go to the local Ford dealer and have a gander at the computator for the Sierra diff Quote
Symbiotic_Caterpillar Posted April 29, 2008 Posted April 29, 2008 The part number for the one in my diff is in this post. It takes a bit of a fettle to get it to fit. Quote
