Sorry, not on the westfield.
Its on the ford escort (see other thread) which I am taking to the scrappers.
The tank is full, yes full and in todays climate that would be much better in my tank.
I've had a pipe down the filler cap but its a plastic pipe with two bends before it drops into the tank so not much hope of getting in from there.
Anyone done it, got a cunning plan.
If it's going to the scrappers, why not just cut away the plastic pipe with 2 bends close to the tank, then just shove your syphon straight in, you obviously dont have to worry about any damage to the surrounding area, so just go for it, either that or disconnect the outlet pipe.
this isnt the best thing to do but could you not just very very carefully drop the tank off the car. my sierra donnor had some left in that i couldnt siphen off. it was only held on by a couple of straps and bolts i supported it all on a troly jack and then let it down gently.
Safest way, IMHO, is to connect a length of fuel hose to the fuel pump output, other end in another car's tank and then apply 12v to the fuel pump and let it pump the contents out.
Kevin
Yeah but dont forget a FULL tank will be heavy  :suspect:
Ok cheers boys, rear wheel removed, hole drilled in the plastic pipe and tube thread into tank, 20l jerry can and a full tank in the Saab = Happy (slightly smelly) Pikey!!
I'm sure they'll be a  scouser along in a minute to let you know how to do it!
Aah I knew my idea was the best  :laugh:  :laugh:  :laugh:
Quickest way toss a match in there  :p
soon be empty  :laugh:
Park it in a dark alley, some geezer will soon empty it for you!
OI!!!! you lot!!!
I represent those last remarks :p  :p  :p
I just get the wife to suck hard :laugh:  :laugh:
OI!!!! you lot!!!
You cant beat a good bit of suction  :suspect:
