I'm running a Duratec with Weber Alpha throttle bodies standard factory setup) and it looks like I need to add a second return spring based on reading some old topics.
Does anyone have any experience of adding an extra spring they would like to share? It looks like I can run one alongside the existing one at the throttle body end where the cable meets the linkage, but there is no where else I can see to fit one even if I start manufacturing brackets etc.
Obviously I am planning ahead here as I don't need this until scrutineering at Aintree on Saturday! What was that saying about proper planning?  :)
If you can PM me with your email address. I can send you a solution when using twin 40's, but have no idea what relevence it has to TB'S. But may be of some help to you.
I don't think the double return spring is relevant to TB's...only carbs....need corroborration
Throbble botties already have built in returns  ;)  :D  ;)
Double return springs is only relevant to Carbs - again its one of the old bits of rules and legislation that hasn't been updated  ;)  ;)  ;)
Ta Obelix :t-up:
:p  where's our team VX stickers  ;)  ;)  ;)  :D  and will Mr H now be "Getafix"  :D  :D  :D
Thanks all. One less thing to worry about.
