flat_four Posted April 16, 2008 Posted April 16, 2008 Anyone have a decent map for a Ford Sigma engine running an Omex ECU that they wouldn't mind sharing? I have the base map which Omex supplied but the engine is a nightmare to start, appears to run rich throughout the rev range and doesn't rev at all cleanly below about 2k rpm. I've got my SVA in a couple of weeks so can't drive it to the rollers before then, and there's no way it will pass at the moment! I've checked the TPS position and signal and that is correct as per the manual. For info, it's a standard 1600 Sigma running the Jenvey DTH throttle bodies, standard injectors and using an Omex 500 ECU (the map Omex gave me was converted from a 600 - don't know what difference that makes...) Hope someone can help! Cheers, John
