I'm going away for 4 days tomorrow and something I want off ebay ends during that time, has anyone used Auction Sniper or similar sucessfully? It claims to do what I want.
Absolutely, excellent piece of kit.  I use www.auctionsniper.com.  Set it to 5 seconds.  When I signed up they were offering 3 free snipes plus 3 more for every friend you introduce.
FBB
Yes used that one aswell,just once on free trial,worked for me :t-up:
Not sure what happens if more than one bidder is using it.
Graham.
Gis your ebay name fbb and you can have another 3...
yep used it many times and it works a treat
just make sure its set up correctly as its a real pi**er when it doesn't work cos your password was not correct
QUOTE
Thanks for the offer, the way it works is I have to submit your email address, then you get sent a link and I get the freebies.  Don't worry about it now, too much hassle and I have a stockpile of free snipes already.  Best of luck,
FBB
QUOTE
Excuse my ignorance - but why? What do they do?
they place a bid for you in the very last second automatically.
very usefull if an auction finishes at a silly time or if you are not near a pc.
but also makes sure you are the last to bid. (usually)
But, as Dabar says, what happens if more than one bidder is using a sniper?
One with the fastest link and computer wins  :p
Remind me not to do business with you dodgy lot  :p
Okay, I admit I used one a couple of times but I do feel guilty afterwards which last until I get my much wanted item  :)
depends who has put in the higher max bid
if they both use a sniper tool the higher max bid will win
if they are the same max bid then it will be down to the first who bid that wins
no different from normal
Oh, OK. Thanks :t-up:
