Hi
I've seen a number of westies with mud flaps on the front cycle wings.  Is this a good idea or are there draw backs to fitting them.  I would like to do something about the amount of c**p that is thrown over the car and passanger when driving on anything less than clean and dry.
Jeff
Made mine out of 4mm rubber sheet and secured them with pan heads
Formed them slightly on the width so they keep their shape
Aslong as you don't make them too long they'll be fine
They stop alot of the stones and s**t from going up the side of the car    :t-up:
£5 Halfords hard plastic mud flups on mine, same as Steppenwolf's, though I didn't realise he had wider cycle wings, since I had to cut the beading off mine. Stops some of the crap though. :t-up:
and don't reverse up a kerb
:0     Even if you ain't got mudflaps    :oops:    :down:
I was referring to demi-kerbs ;)
Mine made from the front and back of a plassy oil can , just cut to shape and mounted with 3 nuts / bolts on each .
Very light  :t-up:
Very cheap  :t-up:
Very Green  :t-up:
been on car for 3 years have done 2 C2C etc still going strong .
Save the Planet  :)
You too can have Mobil 1 on one mud flap and the specification of synthetic oil on another!! ;)
Always a goodn cosurce of materials though
A few of us have fitted these click, certainly keeps down a lot of the cr@p. I have them  just long enough that they scrape the ground at a few mph but clear at about 10-15mph.
I have a pair made from the clear plastic strips that are used at the entrance to warehouses, factories etc. The type used to allow fork lifts in and out "if you know what i mean". They on the whole work quite well, but not up to the conditions at Ty Croes    :arse:
Thanks Guys
I'll get some rubber and make the flaps.  I was concerned that flaps might guide stones and stuff up the inside of the cycle wing causing a jam between wing and tyre. :D
Jeff
If someone wants to make a set of templates I'll get them made in KAYLAN (used by all the works rally teams) and WSCC members can have them at cost !! :t-up:
I would certainly suggest some. They would've stopped most of the dead rabbit I ran over covering my arm. Which was not so nice.
What thickness Kaylan do people suggest. Would 3mm be too flexible and bend up too much at speed, or would say 4mm, thick be better?
Well, Rory's Dad was kind enough to give me some rubber - thanks Martin.  All I have to do now is cut the rubber to size and fit them.  Does anyone have any advice on the best way to attach them to the cycle wings? :D  :D
Unless anyone says differently I intend to attach them using two M5 button head screws, washers and nylock nuts; what do you think? :oops:
Regards
Jeff
