Fuel Consumption/Economy
I am a new Westfield owner and I am sure this question has been posted before.
But, I am wondering what MPG other users get for their cars, I'm sure my carburretors need adjusting/servicing. I've done very little miles (but spirited) since I got the car (poor weather etc) but I'm only getting about 15-18 mpg.
I've got a standard engine pinto 2l , dellorta 40 with the usual mods etc.
If someone can tell me what to expect from a well set up car (what I intend to do in the future).
Urban/rural/combined (frisky) etc?
I have a 2 litre Zetec on Weber 40's. I get around 120 miles on 19 litres - 28 mpg or thereabouts.
I did have to tune my carbs, and at one stage I was only getting 20 mpg. If your engine is running rich you will probably get a lot of soot coating the rear of the car.
Thanks, I know its running rich it has all the symptoms. you've given me a target to aim for when I get it sorted.
Its like pouring half a tank of fuel down the drain... Ouch!
I've a cross flow which gives  around 22 mpg, sometimes upto 24 ish. This is apparently typical- if you get in this range I'd say it was about right. Doesn't seem to matter if you take it easy or not
Modern 16 v lumps should be a bit more efficient.
Plenty of opinion here.
Could you describe the "usual" mods? There's not really much in the way of "usual" when talking about Westfields. They're all different... ;)
Remember though, slightly rich is better than slighty lean. *Very* rich is bad for the bores and rings. *Very* lean is bad for compression 'cos you'll melt a piston...
I got a 2.1 pinto, twin 45 carbs, stage 1 head with race cam. When on the Big roads crusing in 5th i be getting over 30mpg but drops to half that with a little spirited driving on twisty stuff.
Belated response to Blatman, the engine is a ex sierra pinto, 1993 cc. Dellorta 40 twin carbs and kent fast road cams (these being the usual mods). There has been no serious tweaks, thats for certain.
I dont expect brilliant fuel economy but 15-18 I know is rubbish.
I think the previous owner fiddled with the carbs to get it to start, it still takes an age to start from cold.
I know its running rich, and intend to look (get someone to) at the carbs soon.
What I was hoping to find out was an average consumption for a average set up car, something to aim for when all is running well???
Yeah my 1700 crossflow with 40's gives me about 100 miles per tank, approx 25 mpg
I have found it totaly depends how you drive. Like i said earlier you can cruise nice and steady on motorways etc and get 30+mpg but get in to the spirit of things on twisty roads with lots of gear changing & 15 to 18mpg sounds about right. Go balls out & i bet you can get into single figures....So what you getting sounds not too far out mpg wise. But would defo get the carbs settup. I had mine done at dave boggs, that old geezer is a wonder with carbs especialy on pinto's. Charged me £50 all in with runs on rolling road.
Assuming your not driving it like a nun, 15-18 is not *that* horrendous, it certainly deson't indicate a major problem. A good setting up is all that will be required.
It's is hard to get a true MPG firgure from a Westfield, because they are to hard get *truely* brim full, which makes getting a datum to return to hard work. FWIW, most people get 100-150 miles out of a tank under normal conditions, depending on how good they are at filling it, carbs or injection, etc.
This can also get as low as 50-60 miles if your using it as intended on a track.
QUOTE
You must need new glasses :p Brimming either of mine is a piece of P**s...
anybody have contact details or phone number for dave boggs as in above quote ???  ???
I normally get bored and give up before that few litres go in...
:blush:
Diggsy,
Bogg Bros,    Tel 01944738234
They are in east lutton near Malton.
Tell them they been rcomended from WSSC
:blush:
A low boredom threshold is the sign of an active mind...
