Mike Lloyd Posted February 17, 2008 Posted February 17, 2008 Can anyone help me with the wiring connections for the Westfield hazard lights Switch? I am using a premier loom, I have looked in the Westfiled build manual and surprise..... the pin no's do not match up with the pins on the switch. Any help appreciated I have tried to work it out using my DVM, however there are seven pins and I struggle on any more than three Quote
Mike Lloyd Posted February 18, 2008 Author Posted February 18, 2008 Anyone got a Westfield hazard switch and access to the back of their dash, please check which colour wires go to which pins. Many thanks Quote
Tigger Posted February 18, 2008 Posted February 18, 2008 Mike, Not sure if it's going to be any help but I have a diagram using a premier wiring loom and Durite switches (bit chunkier than standard westfield) which you can view online? CLICKY Tiggs Quote
Mike Lloyd Posted February 18, 2008 Author Posted February 18, 2008 Thanks Tiggs Almost very helpful, wish the premier loom came with circuit diagrams they make a lot more sense! Unfortunately pin layout is different to the Westfield switch. Someone must have their dashboard out and the back of this switch showing Looks like it's a call to the factory Quote
adamnreeves Posted February 18, 2008 Posted February 18, 2008 Mike, Click here, does this help, if not I can check my loom if you wish, let me know. Quote
Mike Lloyd Posted February 22, 2008 Author Posted February 22, 2008 Thank Adam My switch only has pins 1,2,3,5,6,8 i.e 4 and 7 are missing, the numbering of the wires in the post (as in the westfield manual) don't correspond with the pins on the switch Quote
adamnreeves Posted February 22, 2008 Posted February 22, 2008 Thank Adam My switch only has pins 1,2,3,5,6,8 i.e 4 and 7 are missing, the numbering of the wires in the post (as in the westfield manual) don't correspond with the pins on the switch My loom is out so I shall take a look tonight and let you know. Quote
adamnreeves Posted February 22, 2008 Posted February 22, 2008 Okay Mike, Here's a photo of the reverse side of my Westfield switch and loom. The switch pins are numbered: 10 9 8 7 6 5 4 3 2 1 As you can see: 1=light green 2=purple 3=green/white 5=green/red 6=pink/green 8=green 10=black highres Quote
Mike Lloyd Posted February 22, 2008 Author Posted February 22, 2008 That's great, thanks Adam. Much appreciated Quote
