Cam Posted February 13, 2008 Posted February 13, 2008 Has anyone got a picture of their battery isolator and pull handle for the plumbed in extinguisher, on the drivers side of the scuttle as per the blue book............Preferably on a WF fitted with a full cage please. Quote
Darren B Posted February 13, 2008 Posted February 13, 2008 Hi Cam, Not a particularly close up shot but both the external handles (battery and extinguisher) sit nicely in the triangulated bit of the 'Caged' cage on the drivers side of the scuttle. My internal battery cut-off is on a small plate that sits on the tunnel just under the dash and the internal extinguisher is on the dash itself. Quote
conibear Posted February 13, 2008 Posted February 13, 2008 My kill switch and extinguisher pull are just forward of the cage triangle that Darren mentions. Pull is furthest forward, I can't reach this but then I don't need to co's it's for the marshals The electrical kill switch should be reachable by the driver, whilst seated normally as it is not only for the marshal use but also the driver. Internally, the driver needs to be able to reach the extinguish pull whilst seated normally HTH Quote
