John Williams (Panda) - Joint Manchester AO Posted February 11, 2008 Share Posted February 11, 2008 just doing a wak through on the car ready for SVA and noticed i might have a problem with the external projections on the adjustable suspenstion nut (the bit you adjust the ride height) on the front. Has anyone had expereince of this and what did people use to fix it? thanks as always john Quote Link to comment Share on other sites More sharing options...
kipford Posted February 12, 2008 Share Posted February 12, 2008 Defo potential problem at SVA. I used a mountain bike inner tube wrapped around the offending item and secured using tie wraps. In still on the car 4 months later Quote Link to comment Share on other sites More sharing options...
John Williams (Panda) - Joint Manchester AO Posted February 12, 2008 Author Share Posted February 12, 2008 Cheers for that..... just got the test date through of the "4th March". cheers john Quote Link to comment Share on other sites More sharing options...
Dargy Posted February 12, 2008 Share Posted February 12, 2008 I had mine covered for SVA at Nottingham and the examiner said I didn't need them covered, so it just depends on who tests your car. Good luck Quote Link to comment Share on other sites More sharing options...
Symbiotic_Caterpillar Posted February 12, 2008 Share Posted February 12, 2008 I used some of this stuff It worked very well. Quote Link to comment Share on other sites More sharing options...
stu999 Posted February 12, 2008 Share Posted February 12, 2008 I had mine covered for SVA at Nottingham and the examiner said I didn't need them covered, so it just depends on who tests your car. Good luck Depends on your car rather than the tester. Depending on where the adjusters platforms are set, or what make shockers you have fitted, or what length/poundage front springs you have etc etc all makes a difference as to whether you need to cover them or not. Westfields (and their sum of parts) are not all the same Quote Link to comment Share on other sites More sharing options...
kipford Posted February 12, 2008 Share Posted February 12, 2008 I followed the approach of murphy's law with all the potential SVA traps. You can always take the stuff off after getting the prized MAC. Quote Link to comment Share on other sites More sharing options...
