Any thoughts as to whether this is suitable for a basic setup post suspension rebuild?
4QQssPageNameZWDVWQQrdZ1QQcmdZViewItem" target="_blank">Clicky
Rich
I use a 1metre spirit level held vertically to check camber. Castor is fixed
I did a bit of trignometry which established that 1 degree of negative camber = 2 washers taped to my level (or something)  :D  :D  :D
Rory's Dad
If its on your car Terry it will never be fixed  :D  :devil:  :D
These are handy fixed to a straight edge; will get you somewhere close but there is a lot more than just setting camber angles when you need suspension setting up - Westfields respond really well to accurate alignment.
oryZ64814QQssPageNameZWDVWQQrdZ1QQcmdZViewItem" target="_blank">Wixley inclinometer
And of course if you are setting camber relative to a fixed plane, the floor for example, it either needs to be level or you accomodate the out of true.
I tried setting camber on my build and after struggling for a while found the floor was not horizontal so gave up :(
excellent i have been trying to find something similar for ages :t-up:
Following from Kerry.... A builders square against the wheel and the floor is still IMO the best bet if your garage floor is not absolutely spot on  otherwise with a spirit level you will build in more camber on one side than the other due to the car not being level.
- Use your "o" level maths trig skills to work out how much bigger a gap you should have at the top of the wheel rim verses the bottom, as this forms a triangle:
 tan camber angle = ( difference gap to side of square top and bottom of rim)/(wheel rim diameter).
tan1 deg = 0.0174
tan 2 deg = 0.0349
I used this method on mine and when it was later proffesionally set up it was spot on.
Someone on here had a great tracking gauge made from a plank and two shelf brackets too
tan1 deg = 0.0174
tan 2 deg = 0.0349
The wixley guage has a 'zero'function so you can set it to an unlevel floor and saves the trig' on a hungover head  :D  :D
Like I said previously camber is only a small part of a geo set up though.
I use the wixley guage for reading rotor pitch on my rc helicopter and it does work quite well  :D
I can't believe any toolkit could possibly be complete without something called a "Wixley Inclinometer"!
Cheers Nikpro. Appreciate the advice on the full professional setup and have every intention - this'll help with the initial job by me before the drive to Procomp tho.
