PreLit Wishbone bushes
Hi
As part of the general refurb I want to replace the bushes in my pre-lit wishbones - not that they look overly worn just thought it was a good idea whilst I have it all to bits...
Problem is I don't know what they are? Are they a Westfield only part or are these taken from a doner vehicle?
Sizes are (approx)
Wishbone "joint" length - 35mm - height 28.5 mm
Bush (metal/rubber/metal)
                      10
                 <-- 16 -->
     <-------------  22 ------------>
<------------------  25 ----------------->
Hope this makes sense  (10mm inner metal diameter, 16mm outer metal diameter, 22 rubber outer, 25 outer metal diameter - all fits in the 28.5 height above)
Craig
fit nylon ones from westfield to the front if you do rears fit metalastic bushes
May be worth a shufty around the Moss Europe web site.
Previous pre lit discussion is here and a link to some other bits on the Moss web site is in this thread.
Post number 55 here *might* even take you straight to the right part...
