smosar Posted January 26, 2008 Share Posted January 26, 2008 Hi Can someone supply following torque settings Bottom Joint Top Joint Track Rod Ends Shock Absorber Top and Bottom Front and rear Just aquired a car and would liketo check!!!!!!! Quote Link to comment Share on other sites More sharing options...
Reidy Posted January 26, 2008 Share Posted January 26, 2008 Front Lower ball joint (maxi type) to wishbone? 28lbf ft 38Nm Front lower ball joint to upright? 25lbf ft 34Nm Upright to steering track rod end? 28lbf ft 38Nm Shock absorber bolts 30lb/ft Calipers to standard uprights 40lb/ft Hub to disc bolts 32lb/ft Hope that helps mate. Quote Link to comment Share on other sites More sharing options...
smosar Posted January 26, 2008 Author Share Posted January 26, 2008 As Usual Thanks for the prompt response looks like a little job tommorrow!!! Quote Link to comment Share on other sites More sharing options...
