Garage Clear out, help me get to Formula Ford!
Hi All,
I'm doing the usual clear out stuff, need to raise money for racing this season.
In no particular order:
Item Descrption
Polo Rad, 35mm thick core, good condition £sold
Polo Rad, 25mm thick core, V good condition £30
Polo Rad ducting, Fabricated radiator ducted box. Bolts straight on. £sold
English diff, 3.89 ratio, mint condition, new bearings, gasket, just rebuilt by Fostek Engineering, never used. £SOLD
English diff, 3.54 ratio, as above condition, used at Snetterton once, mint condition. Prepared by Fostek Engineering with all new bearings and gasket. Fitted with small westfield flange, ready to race. £SOLD
Tyres, 1 full set of Avon ACB 10's, 3mm tread, road legal, BARC Westfield championship tyres. £sold
Tyres, 1 full set of Avon ACB 10's, 2-3mm tread, road legal, BARC Westfield championship tyres.£30 the set.
Zetec Sump, Like new, ready to bolt on. Could be chopped to make like a Schalor or Dunnell. C/w gasket, pick up pipe and sump plug. Used once only at Oulton. Photos can be supplied to show how to chop and modify. Sold
Zetec Engine pulley Covers, Brand new, oil pump and water pump plastic engine covers. £sold
Zetec Oil filters, 3 off brand new shallow oil filters  £8.50 the lot.
Zetec Thermostat housing, Second hand thermostat housing, carried as a spare last year. Bit dusty good condition, no cracks. £18
Sealey voltmeter and Ammeter, Like new, only used a few time, Sealey BT91/5 Voltmeter and Ammeter. RRP £145,   My Price £80
Westfield Body work, Drivers side rear wheel arch, black. Damaged below light cluster, but passes scrutineering £35
Zetec water pump, bit dusty, carried as a spare last season £10
Zetec oil pump, bit dusty, carried as a spare last season £SOLD
M16 brake caliper, new seals fitted, left hand side £30
5 speed type 9 gearbox, partly striped, all bit still with box. Has bell housing and gear stick attached. Very good condition inside. Bought from a westfield owner who had it in his road car. Just needs reassembling.  £35
New Items:
One set of dunlop all weather tyres three meetings old, good condition: Sold
Ford Zetec Starter motor, very good condition as borrowed by Andrew Spencer at Pembrey, fits Type 9 or Rocket gearbox bell housing. Apperently the same as a sierra. This was carried as my spare last season. £sold
I have lots more bits to hunt out and will add them as and when I get to them. If you are look for something which isn't here, then drop me a line cause I may have what your looking for.
Photos can be supplied as required, please fell free to contact me,
Mobile 07762 069088
Home 0191 3889429
Regards, Peter Daglish
Kevin Keegan land I think?
Hi Peter,
Is the Zetec sump the standard style that would usually ship with the engine or a shallow one. If you could let me know I might be interested.
Also where abouts is the item located ?
Cheers,
Martin
Pete's located Chester-le-street. Have texted him to let him know your interested in sump and he'll get back to you when he finishes work.
Might be interested in the 3.89 diff myself
All items located in my garage in the North East.
The tyres are 13" apologies for not putting that on the ad.
The sump is the standard which you get when you buy the base engine. It is the one with the big cut out that most people fill out for bigger capacity. Like I say I have the photos for how to modify and baffle.
Happy reading.
Pm sent about tyres. Thanks for reading ad.
Peter,
You have PM
cheers
andy b
Is there an LSD with the 3.89 English axle ? If so I'm interested.
Pm sent about Sump.
All diffs now sold, thanks for viewing advert.
PM sent regarding oil pump & starter
Mitch
Engine pulley covers still available?  Are they postable?
Rob
If anyone wants any of this stuff taking to the speed series awards I could possibly meet Peter to collect
PMs sent to Mitch and Rob.
