suspension bushes
hi can anyone tell me if the sus bushes are the same size as locost or have i got to go to westy. + any recomendations on elsewhere to go to get them?
ta
ky.
If your asking if Westfield suspension bushes will fit a locost....then I can't answer you query.  If you want an alternative supplier for a set of Westfield polybushes then try Rally Design who do a Westfield kit  :t-up:
yes there 4 westy will try rally design thanks!
And for the record, there isn't a 'standard' sized bush for a Locost... :)
ta
ky.
Locost polybushes are considerably larger. Westfield ones from Rally design come in yellow polysport or red polyrace with stainless inserts.
Polysport ones are part number PB121. A set of 18 Westfield bush assemblies for all the wishbones on an SeiW is £63.
