DTA ECU E48EXP
I'm selling my spare E48EXP ECU which has had around 15hrs engine dyno use only and never been fitted into a car, comes complete with manual, software and PC serial comms lead (you can also download manuals and software from DTA Downloads
This ECU handles both spark and fuelling, uses all the std sensors (eg K series, air + water temp, TPS and hall effect crank sensor) unlike the S40/60 that DTA have replaced it with - see below for full list of features.
Cost new was £550+vat, will accept £400 inc p&p.
More pictures here  and here
pm me or email sgilks@netapp.com
Stuart
E48 EXP ECU Main Features
- Full Ignition control and amplification for up to 4 cylinders distributorless, 8 cyl with distributor
- Full fuel control of up to 16 injectors (staged and switchable on RPM in 2 banks )
- Amplified Coils Support  NEW
- Compensation for air temp / water temp / MAP or barometric pressure on fuel AND ignition
- Closed loop Lambda control
- Turn off closed loop above TPS & RPM  NEW
- Full turbo pressure control variable by RPM with overboost protection
- Manifold Pressure as main load  NEW
- Full single gear traction control (launch control)
- Steering wheel button controlled start line RPM limit
- Full power shift cut
- Temperature dependant Idle speed control via PWM valve (shared second bank of injectors)
- Auxiliary output switchable on RPM / water temp / manifold pressure (shared turbo control)
- Dedicated shift light output
- Dedicated Tacho output
- Two stage main RPM limiter
- Dedicated fuel pump control
- Full startup fuelling map
- Improved idle speed control  NEW
- Throttle transient enrichment map
- Self test facilities for ignition and injection
- Sensor diagnostics and peak recording
- Real time mapping, no EPROM's required, PC only or PC+Dyno Control Box
- Voltage in warning limits during Mapping  NEW
- Software programmable for most crank wheels (BMW, Ford, GM, Porsche, Renault, Honda Blackbird, Rover, VW, 361, 602 etc.)
- All main 3D maps (20 x 14) have user programmable break points on throttle and RPM
- Max. RPM 14,000
Yep...
How yep?  :D  just the job perfect ???
Pm`d
Pm`d but no reply since 1st one!? anyone know if he is away??
Oops - serves me right for being ill over xmas.
sedsy, you have pm.
Stu
