Type 9 output shaft bung
I seem to remember, in the dim and distant past, you could get a nylon bung to shove in the prop end of a type 9 gearbox to stop all the oil running out.
Anyone got one they want to sell? or know were I could get one.
If not how about the splined end of a prop that I could modify.
:xmas:   :xmas:   :xmas:   :xmas:   :xmas:   :xmas:   :xmas:   :xmas:   :xmas:
Not broken that lovely gearbox have you mate?
Cam i may have some suitable rubber bungs/gaitors ! can you give me some rough measurements etc and i`ll see what i got. Alternatively you could just tip oil all over the drive like Neil and i did with mine!!  :p  Or why not fit a remote filler thingy??
Sedsy :xmas:
rubber glove and cable tie
serves as a comedy moment as well
Gearbox is still happy Scott, I just get p****d off tipping expensive oil all over the garage floor  :durr:   :durr:   :durr:
Sedsy.... will take some measurement tomorrow  :t-up:   :t-up:
Rubber glove  :D  :D  :D  :D  :D
Cam
If Sedsy can't help, give me a size and i'll see if we have some Nylon i can turn to size for you
Cam
That was the other method I was thinking of Perksy............... :t-up:  :t-up:
Will get a size tomorrow
IIRC - 32mm or 1 1/4" domestic waste pipe does the job. Cut a short length and seal one end with whatever you have to hand. A rubber bung with RTV sealant did it for me.
Crash
Crash
Cheers Crash, that has got to be worth go  :t-up:  :t-up:  :t-up:
Sedsy & Perksy hang fire I'll report back
Crash
That's the trick you can even buy a blanking cap to fit.  God bless the pumbers merchant again :D
Just use the front joint of an old sierra propshaft. Plenty in the scrappies. Works for me.  ;)
