Duratec Thermostat Housing
Looks like the thermostat has packed up on the Mondeo, :down:  Mr Ford wants £80 for one. :bangshead:
Apparently you have to replace the housing as well as the thermostat. ??? Is this right?
So I thought I would ask on here to see if anybody has a unwanted spare before dishing out the £80+
Mitch :xmas:
Hi Mitch
Is it this one as fitted to the 2.0L with the eleccy connector....if so I think I should have one in the garage. I'll have a look tonight
Hi Cam,
Yep thats the one.
Let me know how much you want for it, if you find it.
Mitch :xmas:
Cam - if you have one spare is it because you removed it & fitted something else in its place ??
I have fitted the Racline Water rail / Thermostat system - I then broke out the thermostat from the Ford housing in your piccy, but noticed the other day that it's leaking around the Electrical connection / gasket.
Thought I'd heard the Mazda unit was just a standar mechanical stat without the electrical connection.
Hiya Glen
Swopped mine for the Cosworth thermostat assembly (part number PR6595) all in it was £37. Comes complete and just bolts straight in place and I thought it was a dam reasonable price.
I also heard that the Mazda was a mechanical stat, tried a Mazda main dealer but can't remember why I went for the Cossy one instead, I think there was lots of Mazda variations and we couldn't figure out which one it was.
Cheers Cam - will call in at Fords and sort one  :t-up:
