suck the bush when you take it out
...was the high point for me...
And getting drunk and playing with your mates wee (from another thread) is probably the low point.  :0  :D
just done mine got bushes from westfield not to expensive  downside was getting old ones out  :bangshead:
I'm now on my second No6 vice, after snapping the jaw of the previous one. Using the two socket,vice and scaffold pole method.
The vice handle is the length it is for a reason i guess - don't be tempted to put a scaffolding pole on the end :blush:doh!!
i went the hacksaw route tried everything else .as long as your carefull its the easier option if all else fails :bangshead:
  • 2 weeks later...
why are you not going for poly bushes? they're easier to fit & sharpen the handling.
Buzz
Buzz
Didn't realise poly bushes were an option for the metallistic bushes. Already bought the replacements and press fitted them.
Thanks for the advice Buzz,  :t-up: will be useful when we change any of the others. The front wishbones have them as well
I got my pressed in by an engineering company. I only had to do on the rear wishbones to the rose joints. All other bushes are nylon which aren't press fit.
You missed my comment then  :p
