salexander Posted November 30, 2007 Share Posted November 30, 2007 Due to the Winter upgrade programme some parts available: Genuine Westfield alloy inlet manifold for a 2.0 Vauxhall XE, for DCOE Weber/Dellorto or throttle bodies. Complete with water feed and air bleed, studs and nyloks. £65 plus p&p FSE fuel injection adjustable pressure regulator (model AIR004), 8mm tails with solid mount. This is a 1:1 ratio adjustable base pressure regulator NOT a power boost valve. Only been on my sprint car for season and a half. £40 plus p&p (cost around £57 new) Link to comment Share on other sites More sharing options...
