Apart from oil/filter/spark plug/points change etc, what else needs to be done on a Crossflow Westfield service please?
Don't have a manual or anything so not aware of any grease points or what needs to be done.  (trailing arm bushes are ok)
Why Ebay Links? :D
A 'service' will consist of different items, depending on mileage/age. The engine has tappets that need checking occasionally. The propshaft *might* have grease nipples on the UJ's. The brake fluid needs changing every so often, as does the antifreeze. Gearbox and diff oil levels to check.
From there on, it is just a case of giving the rest of the car a good coat of looking at...
