PC Software help Please
As of yesterday my p.c on start up comes up with the following security alert
"The security information is invalid or has been modified the program will be terminated"
Then I press 'ok' and the message disappears an the pc is ready to use & functions normally
I've not added nor changed anything on the p.c for a good while now . Its running windows 2000pro
Any ideas?
Buzz
Could this be associated with your PC's attempt to change the time due to the end of summertime? Check to see if the clock has updated successfully.
Are you running Ulead Video Studio?
If you have any software that has a time limit (eg a 30 day trial) it's possible that a Windows update has modified a file that the trial software uses to work out how many days it has left to run. The new date will then cause it to report invalid security information. If that's the case try uninstalling the trial software and see if you still get the message.
Does the pop up give any clues as to the identity of the programme causing the failure? If not, tracking it down is going to be tedious...
Blats no thats the annoying thing its just as describe in the post, Si yes I do have Ulead video which I haven't used and its on trial I thing but's been on the system for a while now. I don't use it as I've just been given Vegas 5(not installed yet tho') still running Vegas 4.0
Buzz
P.S just checked and there's 'no days' trial left on Ulead video. I guess I just uninstall to stop problem do u think??
Probably worth uninstalling the Ulead thingy. Vegas is much better anyway...
That's the daddy.
it;s top trumps on a google for that error. Uninstall if you're not using it and all should be well in the land of billsberry
QUOTE
A statement so open to ridicule that I don't even know where to start... :p
I don't understand waht you mean :oops:???
All sorted now as suggested Si it was the Unleaded Video
Many thanks to all for your help
Buzz... going back to Billsberryland
