Blatman Posted October 6, 2007 Posted October 6, 2007 You saying I'm gay Have you seen the colour of your car? You can talk, lime green indeed Snot green I'll have you know I'm about to install BustyBlonde9.5. I'll let you know how it turns out in the morning Quote
Lurksalot Posted October 6, 2007 Posted October 6, 2007 We're just putting Sex7.5 through it's beta test. Problem, it's uninstallable. Put the disk in, out it pops. Put the disk back in, out it pops again, you get the idea. Can't be the disk, more than 10 years since it was floppy. Are you putting it in the correct drive slot ? Quote
Asterix Posted October 6, 2007 Posted October 6, 2007 We're just putting Sex7.5 through it's beta test. Problem, it's uninstallable. Put the disk in, out it pops. Put the disk back in, out it pops again, you get the idea. Can't be the disk, more than 10 years since it was floppy. Are you putting it in the correct drive slot ? Good spot, must admit there was more resistance when installing than I thought. Cleaned the install, found the right slot, but then, would you believe it, the Timeofmonth service scan kicked in and the whole system shut down. Currently looking for Aphrodisiac5.0 and InterestingConversation3.2 to see if I can scrub the cache and set the basis for another attempt in a couple of days. Quote
