>Dear Tech Support,
>Last year I upgraded from Boyfriend 5.0 to Husband 1.0 and noticed a
>distinct slow down in overall system performance
>-- particularly in the flower and jewellery applications, which
operated
>flawlessly under Boyfriend 5.0.
>In addition, Husband 1.0 uninstalled many other valuable programs,
such as
>Romance 9.5 and Personal Attention 6.5 and then installed undesirable
>programs such as NFL 5.0, NBA 3.0, Nascar 2.0 and Golf Clubs 4.1.
>Conversation 8.0 no longer runs, and Housecleaning 2.6 simply crashes
the
>system. I've tried running Nagging 5.3 to fix these problems, but to
no
>avail.
>What can I do?
>Signed, Desperate
>Dear Desperate:
>First keep in mind, Boyfriend 5.0 is an Entertainment Package, while
>Husband 1.0 is an Operating System.
>Please enter the command: "http: I Thought You Loved Me.html" and try
to
>download Tears 6.2 and don't forget to install the Guilt 3.0 update.
If
>that application works as designed, Husband 1.0 should then
automatically
>run the applications Jewellery 2.0 and Flowers 3.5.
>But remember, overuse of the above application can cause Husband 1.0
to
>default to Grumpy Silence 2.5, Happy Hour 7.0 or Beer 6.1. Beer 6.1 is
a
>very bad program that will download the Snoring Loudly Beta.
>Whatever you do, DO NOT install Mother-in-law 1.0 (it runs a virus in
the
>background that will eventually seize control of all your system
>resources).
>Also, do not attempt to reinstall the Boyfriend 5.0 program.
>These are unsupported applications and will crash Husband 1.0.
>In summary, Husband 1.0 is a great program but it does have
>limited memory and cannot learn new applications quickly.
>You might consider buying additional software to improve memory and
>performance. We recommend Food 3.0 and Hot Lingerie 7.7.
>Good Luck,
>Tech Support.
>Peter Shaw
>NHSCR Team 2
Another good bit of additional software to make Husband 1.0 run better is Kinky 6.6 and Sex 4.2. ;):)
you only get 4.2 sex ??
I would ask for an upgrade
you got a husband  ???
you keep your programs to yourself  :p  :p
Just downloaded Sex 6.9  :p
You saying I'm gay :p:D:D
There are pills for that ;)
QUOTE
You saying I'm gay
Have you seen the colour of your car?
You saying I'm gay
You can talk, lime green indeed :p
Sometimes I wish I hadn't been upgraded, as version sex 4,1  was a lot less complicated and was happy to run on it's own with very little support  :devil:
:D:D
We're just putting Sex7.5 through it's beta test. Problem, it's uninstallable.
Put the disk in, out it pops. Put the disk back in, out it pops again, you get the idea.
Can't be the disk, more than 10 years since it was floppy.
have you tried giving it a clean?
they are usually accepted more readily :)
