SEiW Dunnel 2.0 Zetec
Due to a change in circumstances I am reluctantly selling my Westfield.
Originally built in 1997 but completely rebuilt in 2005 with the intention of doing sprints and hillclimbs (although I never had time). The rebuild included replacing pretty much everything, including completely new suspension (dampers, springs, wishbones), steering, braking system, cooling system, electrics, bodywork, seats, harnesses, instruments and gauges. In fact, the only bits not replaced were the chassis, engine and diff. Since then I have fitted a new Quaife gearbox and Jenvey throttle bodies with Emerald 3D ECU.
The car is immaculate and my pride and joy and I guarantee you won't find a better prepared and properly set up car for the money. If you have any questions, please ask.
The full spec is:
Westfield SEiW
Race chassis
Dunnel 2 litre Zetec giving over 200bhp on Jenvey throttle bodies
Emerald 3D ECU (mapped by Dave Walker at Emerald)
Widebody race chassis with independent rear suspension
Welded in RAC rollbar
Lightweight bodywork in black with detachable rear arches
Bonnet exit stainless exhaust and 4-2-1 manifold custom-made by JP Exhausts
Procomp widetrack front suspension (mainly rosejointed)
Procomp front and rear ARBs
AVO aluminium bodied adjustable dampers with spherical bearings and 2.25" springs
Full set up including corner weighting by ProComp
Quickrack
Cortina uprights modified for correct Ackerman angle
Aluminium hubs
Bias adjustable brake bar
Wilwood Powerlite calipers with Wilwood pads (front)
Aluminium Golf calipers (rear)
Lightened and cross drilled brake discs
Quaife semi-helical Heavy Duty Type-9 gearbox built by SP Components (capable of taking up to 275bhp). Ratios are: 1st - 2.39 2nd - 1.54 3rd - 1.21 4th - 1 5th - 0.87
Ford Sierra 3.92 LSD
Bailey Morris Prop Shaft
Stack 8130 dash
Momo removeable suede steering wheel
FIA-approved cut-off switch
Toggle switch starter
Tillet W1 low-back seats
Sabelt 4 point harnesses
Odessy gel battery
Polo radiator
Silicone hoses throughout
Oil catch tank
Raceline water rail
15" Ultralegerras with 195/50 R15 Toyo R888
Interior carpets in black on tunnel and rear bulkhead
Interior panels covered in black vinyl
Weighs in at 560kg with all fluids and half a tank of fuel
MOT June 2008
Tax April 2008
£12,500 ono
Andy
07779 607 686
Sounds an absolute cracking car with a very high spec - will make someone a cracing road / trackday weapon - good choice in colour as well  :D
Cracking car with a fantastic spec.
For the money you're asking, I'd say it was worth every penny! Good luck with the sale, and a great car for someone.
Have to say I know this car/driver and it's a cracking car, Andy does not skimp on things and is a bit of a perfectionist (this shows with the car :t-up: )
Sorry to see that your selling... :(
Again absolutely immaculate car,
must be seen the flesh to be appreciated.
Sorry to see your selling Andy  :(
what colour is it  ???
what does it rev to  ???
Dont do it Andy!
  • 3 weeks later...
SOLD! :(
It should be on its way to Tewkesbury this weekend to a virgin Westfield owner and keen trackday participant. I know he's keen to join the club so I'll pass on his details to the respective AO if that's ok.
Honda Elise here I come... :D
il sell you mine andy  ;)  :oops:
