FACTORY BUILT CLASS A RACER
***Reduced***
This is advertised elsewhere. PM or call on 07968 184107.
For Sale. £5450 ONO
General
Taxed & MOT'd untiI 04/08
16000 very happy miles
Factory built (Jan1997) for racer then sold back to the factory (Nov 1997), then wife's uncle, then me (Jan 2000)
Weight 535 fully wet excluding driver
Year of 1st registration 1998
Year of build 1997
Power source
Dry sumped 1690 Xflow 130bhp/120lb ft spec @ flywheel (and when last dynod) using Valvoline20w/50 racing oil
Engine block Xflow 1690 (1600, 2.5mm 100 thousanth over bored) Kent head
Kent 234 cam
Torque (lb/ft), peak 110 @ 5400 @ wheels
Power (BHP), peak 120 @ 6043 @ wheels
RPM maximum6500 (no limiter)
Big end bolts standard Ford
Bottom end lightened and balanced
Flywheel Lightened/ Balanced Xflow
Chainset Duplex Burton
Compression10.5/11:1
Distributor Standard Ford
Dual valve springs Outer springs 40mm long; 28.5mm outer dia; 21mminner dia Inner springs 38mm long; 21mm outer dia; 16mm inner dia
Weber 40carburettors
Carb filter Westfield sock with backplate
Fuel Unleaded with additive
Head Formula Ford pre 75 Xflow
Head Gasket 83.5mm competition head copper Gasket
Inlet valves 39.4mm dia7.9mm stem111mm long
Pistons 1300cast, lightened
Shells Vandervell
Thermostat Xflow
Valve clearances 18 in 20 out
Valve spring lower retainers Steel step type
Valve spring top caps Dual standard
Valve stem oil seals Standard
Drivetrain
English non-slip diff
4 speed Ford gearbox
Exhaust
Competition exhaust manifold gasket set
30-odd by 6" repackable silencer (noise test is regularly 94/95db)
Structure
Race chassis (braced front and around scuttle)
RAC rollbar with extension hoops, rear struts, lateral cross diagonal
Bodywork
Aeroscreen
Detachable rear arches
185 width front cycle wings
Soft bits
Tonneau cover (slightly torn), adapted to provide half door application
Race seats
4 point harness in both seats plus a spare 4 point harness
Wheels
13x6 Minilite wheels (not shown in photo's but in VGC...will give £125 cashback if you opt for the RS 4-spokes shown)
Suspension
AVO shocks
Front Westfield standard
Rear Westfield std live axle (Ford)
Control
Floor mounted pedals
Bar bias braking
Removable steering wheel
Steering rack:2.2 lock to lock. Mk2 Escort modded
Instruments Tacho, Speedo, Oil pressure, Water Temperature (all VDO)
Electrics
Battery cut-off
Odyssey gel battery
Braking system
Brake discs (front) Ford Cortina Mk 4/5 - circa 1980
Brake callipers (front) Ford Cortina Mk 3/4/5
Brake pads (front) Mintex1144
Brakes rear drums
Lubrication
Oil Valvoline20w/50 racing (Millers running in oil for running in)
Oil filter Ford Escort - Champion C103
Oil pump Pace impeller
Oil system Dry sump
  • 3 weeks later...
Bdddoing
weekly bounce - good car here awaiting new loving home
***Must not post whilst drunk***
Someone is interested HERE
someone has been PM'd...cheers John :t-up:
  • 2 weeks later...
Sold (blimey, how many cars have sold this weekend)
Hmmm, I hope he took the old one and not the new one :laugh:  :p  :D  :D  :D
When do we get to see the new one then ?
tis this one here mate   CLICKY
Was going Very well at Bruntingthorpe    :cool:    :devil:
