DavidC Posted September 28, 2007 Posted September 28, 2007 As I've decided to go for the Dash2 bulk buy, I have a load of dash furniture which is surplus to requirements. First up, a brand new VDO Cockpit Vision 52mm Fuel Guage. This is the gauge for the float-arm sender as used in the Westfield fuel tank. I bought this from Merlin Msport exactly 1 month ago and it's never been used. £30 incl postage http://i55.photobucket.com/albums....346.jpg Next I have 3 VDO gauges, 52mm for Fuel, Oil Pressure and Coolant Temperature. The oil and coolant gauges work 100% perfectly. I think the fuel gauge does, but I've never had more than 4 litres in the tank (car not completed yet). It may be a dip sender type rather than a float are sender (hence why I bought the other gauge). The fuel gauge has the number 301.271/1/30 on the outer casing. £40 + postage for the set. http://i55.photobucket.com/albums....347.jpg Also, a Bright6 warning light module. NOW SOLDhttp://i55.photobucket.com/albums....348.jpg And finally, an SPA digital speedo. The loom, hall-effect sensor and magnets are brand new and never fitted. The speedo unit is 2nd hand but only has 1.9m on the clock. The plastic front on the display does have a couple of light scratches, but nothing that you'd notice when driving. http://i55.photobucket.com/albums....337.jpg http://i55.photobucket.com/albums....340.jpg http://i55.photobucket.com/albums....341.jpg Will cost you £190 fom DT, £100 + postage from me. That's about it for now. DC
DavidC Posted October 8, 2007 Author Posted October 8, 2007 Bits still left Brand new VDO Cockpit Vision 52mm Fuel Guage. Bought new 1 month ago and it's never been used. £30 incl postage http://i55.photobucket.com/albums....346.jpg SPA digital speedo[/b complete with new loom, hall-effect sensor and magnets. The speedo unit is 2nd hand but only has 1.9 miles on the clock. http://i55.photobucket.com/albums....337.jpg http://i55.photobucket.com/albums....340.jpg http://i55.photobucket.com/albums....341.jpg £100 + postage Finally the 3 VDO gauges, 52mm for Fuel, Oil Pressure and Coolant Temperature. £40 + postage for the set. http://i55.photobucket.com/albums....347.jpg
