Chassis number
Hi all i'm in the middle of buying a westfield sei.
The car is just a chassis and a body.
Alot of work i know but will be worth it when done
The only prob with it is that there is no chassis plate with it as the owner has never had 1.
Wot will i have to do as it aint got 1.
Will post some pics up later
QUOTE
Be very careful  ;)  ;)  ;) copies of chassis do exist  ;)  ;) might be the only problem but it is a major one  ;)
It should still have a chassis No stamped into a couple of chassis rails front bottom cross member and top angle member - check these with Westfield
QUOTE
be prepared to walk away if it doesn't stack up and check out  ;)  :)
wot if everything is all fine with it can i get a new number
If it ain't got a genuine chassis number that clearly identifies it as a Westfield - walk away  ;)  ;)  :)
Chassis plates can be lost at times ................. however chassis numbers are always stamped into various chassis members - no numbers = potentially troublesome - how are you gonna register it for road use SVA, MOT etc etc
would you buy a tin-top without a chassis plate and number ???
shoodunt b a prblm getin a noo pl8 if u can proov 2 westfeeld that u own the chassis.
Could be a stolen or even written off chassis.  Westfield won't recognise it as a Westfield and you'll probably get less money when you come to sell (presuming you can SVA it).
I'd walk away.
jeez Sam, can you write in proper english - not text b*****ks. I'm too old to understand it without reading it 10 times!!  :down:  :bangshead:  :p  :p  :D  :D  :D
John
