wipper Posted September 12, 2007 Posted September 12, 2007 Does anybody know how to work out the wheel offset? I'm replacing my alloys and don't know how to check what the offset is on the existing wheels so I can match them. Quote
pistonbroke 2 Posted September 12, 2007 Posted September 12, 2007 http://www.1010tires.com/WheelOffsetCalculator.asp Quote
adamnreeves Posted September 12, 2007 Posted September 12, 2007 It should also be stamped into the rim somewhere in the form "ET**" the ** being the offset so for example a 37 mm off set would read ET37. Mine aren't stamped. Quote
stu999 Posted September 12, 2007 Posted September 12, 2007 ...And even if they are stamped, the offsets are worth checking anyway, as some manufacturers stamps do not necessarily reflect the actual offsets... Quote
wipper Posted September 13, 2007 Author Posted September 13, 2007 Cheers for all the help guys. Looks like the alloys I'm after aren't available with the offset I want so it's looking like spacers and longer studs! Quote
