Arcam A65 Plus HiFi Amp
Condition: used
The A65 Plus is the DiVA range's entry level amplifier and features the same advanced circuitry and full remote control functionality used in its bigger brother, the A75 Plus, but with less powerful amplifier output stages and a more modest power supply. As before, the new circuits are designed to amplify delicate audio signals without degradation and the clean, pure sound quality will never get between you and the music.The A65 Plus has a built-in MM only phono stage fitted as standard
Continuous Power Output Per Channel
Both channels driven 8 Ohms, 20Hz-20kHz 40W
Single channel 4 Ohms, 1kHz 80W
Distortion 8 Ohms, 80% power, 1kHz 0.01%
Signal to noise ratio* 100dB
Tone controls, max boost/cut +/-8dB
Preamplifier outputs
Nominal output level 510mV
Output impedance ♥Ohm
Power consumption (maximum) 350VA
Size W/D/H mm. inc. feet 430x330x85
Cost £390 when new.
Supplied Accessories
Remote control
Inst book (p/copy)
Power lead
Anyone interested... Ping me an email...
robthehungrymonkey@autex.info
It's located in Brighton, i'd be willing to post, but would much rather have it picked up (less chance of damage in transit), and so the buyer can make sure he's happy with it.
It's in very good condition, thanks.
