AndrewR Posted August 15, 2007 Posted August 15, 2007 Has anyone experience of fitting these covers, there is two halves to each cover. I think they need trimming to shape before fitting. Is it best to retain them using self tappers, or something like sikaflex possibly what do you think. Regards Andrew Quote
jdinhants Posted August 16, 2007 Posted August 16, 2007 Andrew I have had to trim the front edge as my seats are right back against the back panel. Could be a problem with Sikaflex if you need to get the covers off in the future. I am going to use dome headed M5 bolts into an ally fitting which sits in the bodywork that I got from Westfield. Probably put a small amount of black silicone under the cover as a support. Just struggling to get the boot box lid fitted as it seems to be a different shape to the opening J D Quote
