Martin Keene Posted June 26, 2007 Posted June 26, 2007 Hi I'm currently backing up to an external hard drive, and the other day I thought it would be useful if there was some software/freeware that instead on backing up the obvious bits, created a 'ghost', for want of a better word, of the original drive, so should the worst ever happen, it would simply be a case of swapping the drives over. Possible? Martin Quote
John Williams (Panda) - Joint Manchester AO Posted June 26, 2007 Posted June 26, 2007 if you want free and legal, then have a look at http://www.feyrer.de/g4u/#whatisit for basic drives and partitions It is linux based but we have used it at the office, although you do get what you pay for. cheers John Quote
GuyH Posted June 26, 2007 Posted June 26, 2007 There are many out there, the most famous of which is called Norton Ghost funnily enough (from Symantec). clicky Quote
DerekJ Posted June 26, 2007 Posted June 26, 2007 You could use "partition magic" to do this too. Again, it's from Symantec and you have to pay for it too but it's quite cheep. Cheers DJ Quote
ACW Posted June 26, 2007 Posted June 26, 2007 There's ghost by Symantec. This was good in its day about 10 years ago, but since the product almost apears as if the original writter had died and they just keep flogging it. To do imaging it boots into PC DOS which makes it crap to support NIC drivers etc. I use Drive Snapshot which can image a machine whilst in use in windows. I then use a Bart PE boot CD to boot the machine from a bootable CD or USB device (incl memory stick) into a limited version of windows where you can snapshot back. http://www.drivesnapshot.de/en/ http://www.nu2.nu/pebuilder/ Quote
